In hp pl5060n 50 inch plasma tv
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
