The big hunt.
2013 chrysler 300C
which engine is there? 5 engines there are, and not told
the service,manual covers that.
dtc error?
P0196-ENGINE OIL TEMPERATURE SENSOR CIRCUIT PERFORMANCE?????????
not told why asked. (context sure helps)
3.6L answer of 5 engines.
answer from SM
Release fuel system pressure
Disconnect and isolate the negative battery cable.
Remove the air inlet hose, upper intake manifold and lower intake manifold with the fuel injectors and fuel rail
Disconnect the oil pressure sensor electrical connector
remove #2
next time, doing DIY, know what is under the hood first then tell it.
or read the SM your self
https://eautorepair.net/Marketing/Default.asp
