Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
How to clean Bosch washer 100 series filter
Got cap off but seems to have another cap behind it with gasket around it, how do you remove ,,or does it stay
  • Bosch Master
  • 14,826 Answers
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
Posted on Oct 05, 2015
Testimonial: "It has several grooves in the cap that has gasket around it..I don't mean to sound silly. But I see no spring"
6ya staff
SOURCE:
Bosch washer will not spin
Check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Be prepared for a lot of water and junk. If you find a closed hose pipe when you remove the drop down flap it is to drain excess water.
The pump itself is directly behind the filter housing, check if there is nothing stuck in the housing, especially after you are cleaning out your filter after a long time. Clean out and refit carefully
Pl click if helped.
Mar 25, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My bosch wfmc 1001 wont drain. I saw the reply to a similar question and followed the instructions to remove the pump filter however I unscrewed the cap and it didnt seem to want to come out. After pulling...
yes the best person to se would be the engineer or go to the manufactures website and try to get a service manual for it to see an exploded view of the affending item eric
Dec 26, 2017 | Bosch Nexxt 100 Series WFMC1001UC Front...
Does this machine have a filter on the drain line? How do you access it?
The filter should be located at the bottom front right of the washer.
It may be behind a removeable plastic cover at the bottom of the washer.
Unscrew anti-clockwise to remove and clean.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a bosch washer about 3 years old. It suddenly stopped on spin cycle and water would not drain even when I put it to drain only. The motor chatters now like a car with a battery that is dead. Is this...
It does sound like the problem is related to the water pump.
The filter should be located at the bottom front right of washer, sometimes behind a removeable cover.
Locate filter, and remove by turning anti-clockwise, and clean, check inside the filter housing for anything in there as well.
Hope this helps.
Nov 30, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Is there a filter that I can clean out located behind the round cover on the lower right front of my Bosch Nexxt 500 series washer?  If so, how do I get the cover off?
just pop it off with a small srewdriver and yes you can get to the fluff filter through the round cover
when you open the filter there will be about two litres of water come out beware
Jan 21, 2009 | Bosch WFMC 3200 Front Load Washer
Front loading washer does not advance past the rince cycle
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
275 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
