Televison & Video Logo
K
Kay Banks Posted on Oct 05, 2015
How do I get the autoscan to save during initial setup?
It just goes to a new screen stating please complete channel autoscan
I am having trouble with the initial setup of channels, I can't seem to lock in the HD channels when going thru the beginning setup
The normal method is to do a full auto scan and once it's at 100% store or save the scanned list?if you try to do it manually you will take ages because some channels the polarity switches and parameters for the horizontal and vertical parts of the dish change frequency.
so make sure the cable is connected properly into tv or smart box and rescan.once it's reached 100% look for the save or store button on screen.the hd channels should be automatically put within the saved list and usually colour coded in the menu.when selecting channels.
2answers
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
I HAVE A SONY BRAVIA MODEL KDL-40W4100 WHICH IS SUPPOSED TO HAVE tvgos but my tvgos does not work at all, no channel listings, nothing
Be sure to complete the INITIAL SETUP to use this service.
If you have an user manual you may check it out for help to complete the INITIAL SETUP. Or else, you can have the correct page of INITIAL SETUP here:
http://www.retrevo.com/pdf/23566bh638/21/Setting+Up+the+Channel+List+–+Initial+Setup#q=Sony+KDL-40W4100
This link refers you to the page 16 of the user manual of your model. Please check page 17 also to complete the INITIAL SETUP. To go to this link, just copy-paste it in your address bar.
Can't get abc2, abc3, etc. we have a digital set top box. how can we get it to show the chanells?
My set-top box has an 'autoscan' function in the channel menu under setup. Try that to see if it will be able to find the missing channels. Here, some time after the initial changeover to digital, they changed some of the channels, and a new scan was necessary to get all again.
My set top box will no longer pick up certain channels such as itv and channel 4 stations !!
My set top box has setup menu, channels, autoscan to scan for channels. They changed some of the channels here after the original switch to digital, and a fresh autoscan was needed to again find the channels that moved. See if your box has autoscan for channels, and do it.
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
AV 35750 no images only sound with cable, images & sound with DVD
Make sure the cable is on when you autoscan. If the autoscan doesn't see it,manually inputing won't get you there. Make sure you have the correct band selected when you autoscan.
Top Initial Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
