Question about Vision Fitness Exercise & Fitness
How many amps in the Vision Fitness T9500 HRT Treadmill
  • greg kinsley Nov 10, 2015
    Hi Reuben....T9500 can have a couple of different control boards but both will take about the same operating current. At about 1mph setting walking slowly, you should see an input current to the treadmill of 3-5Amps AC as measured with a Kill-a-Watt or clamp meter. As you walk, and step onto the belt, this current will rise or spike with each step as the controller attempts to regulate the walking belt to a set speed. As expected, as you increase the speed and run, the forces to the deck/belt also increase, hence the drive current to the motor will increase or decrease according to the spin speed, speed setting, and feedbacks to the controller and upper console boards. If you are wondering about motor current specifically, that is normally a chopped DC voltage/current provided to the motor from the control board below, according to the console settings up above. Please be aware there are lethal voltages inside most motor control boards, and they should be treated with extreme care by folks aware of where you can and can't "touch". Hope this helps.... greg
    Top Expert:
  • 29,733 Answers
It is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Posted on Nov 10, 2015
6ya staff
SOURCE:
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: squeals on startup for about 1 minute then goes
Remove motor shroud and inspect the drive belt VF is imfamous for squealing drive belts better to call them and order a new belt here is their # 1-800-335 4348 Vision is now under there parent corp. name Johnson
Posted on Feb 28, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
guru_fixya
Natarajan Ramasamy
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
vtechsupport
SOURCE: hi i have a vision
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Posted on Mar 30, 2011
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: I have a vision T9500
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Posted on Aug 28, 2011
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
Does anybody know how to get the total milage on the vision t9500 deluxe treadmill? it is a 2007 model.
please go to www.iconservice.com and download your owner manual for instruction about the how many total milage.
God bless you
Aug 23, 2013 | Vision Fitness Vision T9500 Deluxe...
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Belt is slipping
see the video attached. and fix it. God bless you
Nov 25, 2012 | Dmm Vision Fitness T9500 Treadmill
Vision fitness manual for t9200
see this place and download the instr.manual www.iconservice.com or www. fitness.manualsonline.com
God bless you
Jun 27, 2012 | Dmm Vision Fitness T9500 Treadmill
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
I have the Vision Fitness treadmilll #T9450. When
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
Jun 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Squeals on startup for about 1 minute then goes
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
Exercise & Fitness Logo
162 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Don Eagan
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
