I did a web search for "proscan 26lb30qd manual" and found quite a few results; here's one that looks promising...
http://tv.manualsonline.com/manuals/mfg/proscan/26lb30qd_26.html
SOURCE: Proscan TV Manual
I have a Proscan model # PS36800HRJX1 and having a hard time putting it on DVD mode to be able to play a movie. I just bought a remote for it and can't figure out what's the problem. How do I go about it?
SOURCE: I can not remove the
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
SOURCE: i need an owners manual for a proscan 26lb30qd.
go to philips,support.com -- you can get manuals for free and download one
SOURCE: I need the AT&T
Hello
AT&T U-verse remote control codes for Proscan TV are:-
1000, 1008, 1068, 1094, 1108
OK.
