Locating Your Model NumberThe Model number is eleven characters long and is printed on the left side of the Product Identification Label. Characters can include numbers, letters or hyphens.
Troy-Bilthttps://support.troybilt.com > article
RECENT PRODUCTION tiller models, machines manufactured since 2001, will have a model and serial number sticker normally located on the tine hood of the machine.
Your Home lite equipment will have a model information plate located on the unit. (silver colored) It includes the model number and the serial number. First model no - UL and then below it is the serial number. Check the handle.
The serial number could be located anywhere. Usually it is stamped into the metal--look at the back of the machine or even underneath. Note--older Singers do not have model numbers, only serial numbers.
This may help you learn more about your machine when you do locate the serial number:
Appliances (e.g., refrigerators, dishwashers, etc.): The model and serial number are typically located on a sticker or plate on the back, side, or bottom of the appliance.
Electronics (e.g., TVs, computers, etc.): The model and serial number can usually be found on a sticker or plate on the back, bottom, or side of the device.
HVAC systems (e.g., furnaces, air conditioners, etc.): The model and serial number are often located on a sticker or plate on the exterior of the unit, or on the inside near the blower or evaporator coil.
Power tools and equipment: The model and serial number can typically be found on a sticker or plate on the body of the tool or equipment.
Vehicles: The model and serial number (also known as the VIN, or vehicle identification number) can usually be found on a metal plate on the dashboard or door jamb.
If you're having trouble locating the model and serial number for a specific product, check the user manual or the manufacturer's website for guidance.
Issue:
Where is the serial number located?
Solution:
Locate the serial number MX882
Locate the Serial Number
The serial number of the MX882 is located inside the printer, as shown below.
With the printer powered on, open the Paper Output Tray (A).
The above illustration shows a PIXMA MX870.
Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
Wait until the print head carriage moves to the ink tank replacement position.
To the right of the print head carriage, inside the
printer, is a white sticker that is attached to a metal plate. The
serial number is located on the white sticker. Please see the
illustration below. The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
You'll need the serial code to check for the year, the serial code is located on various locations. Please check this picture to search for your serial number--
After you find the serial number you can calculate the month and year of the washer by checking this coding list--
If this is a Whirlpool manufactured TOP LOADER (such as the one you posted this question under), the model number and serial number are located on a nameplate along the wash tub rim under the lid.
If this is a FRONT LOADER, the model number and serial number will be located along the door facing as you open the door.
If you have questions, please post back and let me know. I hope this helps you.
