Printer is a Kyocera FS1370
SOURCE: The printer will not load the papers
Hi you may try:
1) paper input sensor dirty, clean paper input sensor usually near the tray input roler area there is a micro switch or a led light sensor with two wires.
2) paper input sensor fail or disconnect between sensor and socket on the board, you have to open the cover to check.
SOURCE: Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
SOURCE: Paper not detected in cassette
do you have the paper in the correct position? you can feed from the top or the bottom but you need to select the correct one. hope that helps
SOURCE: messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
SOURCE: My kyocera printer km 1820
cheap kyocera mita copier repair and parts installation just txt or call 09194851549, 09168932315 also offering free estimate within metro manila (ncr) philippines any kyocera mita brand we can fix it!!!
