Toro 22 in self propelled lawnmower The engine starts very well and runs for seconds, time after time. I've - Toro Leaf Blowers ... runs for seconds, time after time. I've cleaned the top of the gas tank - seemed to be the most frequent case. Drained the gasoline and put in fresh
Sounds like the carburetor is clogged. Remove it and clean it with carb cleaner. Use the tie wire that is on commonly found loaves of bread. Insert the wire on all the little holes. Remove the main jet and emulsion tube. Clean wth carb cleaner. Reassemble and fill tank with fresh gas. Should run.
