Tried running system restore, can't run recovery as monitor is not working...don't want to run recovery as it deletes everything on hard drive.
Pick up a second hand monitor, test your system to see if a signal comes through i.e. you have image on screen. before you do a recovery, perform a back up and restore, to a previous date & time. You may just have a bad monitor.
Testimonial: "Thank you. We tried 2 other monitors so, we are sure it is not the monitor, in trying to restore system it said the file I asked about can't be found."
Unfortunately I find no reference to "File 5391ada02". Now before you go and perform a factory reset, or system restore, boot into safe mode and check to see that all of you drivers are up to date, specifically video card and monitors. You should be able to see something on your monitor while in safe mode.
