If I press the start button twice, the motor will start with high speed (correct), and if I then press the button once again, the motor will continue at low speed. So it's only the start at low speed that wont work, if the motor is running at high speed and I press the button for low speed the motor will run at low speed.
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
SOURCE: i have a 2 speed spa motor (K48m2a4) that stopped
Either the low speed circuit is defective or a relay is inoperative. If you feel confident , you could switch the low and high speed leads on terminal plate. The high speed jet button would activate low speed on pump if motor is good.
SOURCE: Motor is hooked up correctly according to
You have 220v running into your motor, the red and the plack are in most cases the same 110v line and what your calling a white netural is a common line. In other words the second half of your 220v line. If your red and black are the two opposing 110v lines that make up your 220v and they are put on the motor and turned on they short aginst each other and blow the breaker. One of your 220v lines should come into your hi -low switch and then split to your high and low on the pump. The other half of your 220v line will go to the common or what your calling nuteral. The difference is a netural completes a 110v circut and a common completes the 220v circut it will take to run the motor. One of the splits will complete the low speed circut and the other will complete the high speed circut. You need to check your voltage comming into the spa, the way the spa is wired (110v-220v), and how the motor is wired (110v-220v). For your spa this will be in your owners manuel or on a scematic inside a panel or door and is quite often a plug you change from one spot to another. On your motor will have a scematic on the back of the motor that will tell you haw to adjust the wireing already in place on the wire board of the motor. This may sound deep but if all your voltages are set the same and your high and low are the same leg of power, this should fix your problem.
SOURCE: I HAVE A CENTURY LASAR POOL/SPA MOTOR W/ A HIGH
Faulty centrifugal switch, internal, faulty, temp sensor, internal, faulty start run capacitor (If used). bad brushes, (If any) Faulty Winding.
SOURCE: Intermittent jet problem on Spa form hot tub
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
