Question about Geneva Watches
It want work /start
The bottom of it i think it is broke because the cap just keeps popping off
    Top Expert:
  • Geneva Master
  • 66,213 Answers
Then perhaps you should put it in the BIN
Posted on Oct 11, 2015
6ya staff
SOURCE:
How do i change batteries on a Casio fishing watch, model AQW-101?
do you see there is a whole in the middle of the metal cap? try using your tweezers to create a lever and put just enough force that it pops open. You can also remove the whole thing out so it is easier to work with. Good luck!
Mar 07, 2013 | Watches
My Nixon Rotolog Leather watch broke at where the leather meets the watch. The bar keeping it together broke. I need a new bar in order to keep the watch together.
This is called spring bar or spring pin. You can buy these on ebay. Make sure you get the right size. The distance between watch lugs is the right size. Measurement must be taken in mm.
May 18, 2011 | Nixon Rotolog Leather Watch
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Bulova 96R31 keeps time + date, but the chronograph does not work
    The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
    Feb 25, 2010 | Bulova Diamond Chronograph #96R31 Watch...
    How do I put the back of the wrist watch on.
    You probably need to go to a watch repair professional. Any business that replaces watch batteries should be able to help you. They have a special press designed to support the watch safely while they snap the back onto the case. This sometimes takes quie a bit of force and rqeuires that the watch case and back plate be perfectly aligned.
    Sep 29, 2009 | Timex 1440 Nylon watch
    Tag Heuer Button Popping Out
    If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
    If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
    Find your nearest watchmaker as both need professional repair and parts.
    Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
    Replacing battery in watch
    sorry to have bothered you, I broke the fixing whilst trying to get the battery out so will have to buy a new one! Why did I bother to try? the new battery has cost me about half the original price of the watch. What a terrible "throw away" society we live in. Thanks for your prompt response will keep you in mind for future problems.
    Jun 22, 2008 | Watches
    Problem with RS200 watch
    it could be that one of the wires inside of it somehow broke
    Jan 22, 2008 | Polar M32 Heart Rate Monitor Watch
    Watches Logo
    Top Geneva Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    NOEL
    NOEL
    Andrew Taylor
    Andrew Taylor
    Are you a Geneva Watch Expert? Answer questions, earn points and help others
