Tablets & eReaders Logo
Delisile Posted on Oct 12, 2015
My tablet fondi T708 battery is dieyng within an hour after charging
Fondi tablet stucks on Android logo
power button and both volume button hold down for around 10 seconds or so and then let go should reboot.
Why does my Fondi tablet not store any apps on the micro sd card?
I just came from CIA where I bought my fondi tablet. The guy I spoke to said there is a safety feature build in to this android 4.4 fondi tablets. You can't store apps on your SD card, only music, photo's, videos, ect. I personally don't like it. It feels like I wasted my money.
Battery will not charge
Your battery may be defective and cant hold a charge. Make sure the unit is receiving power and if so replace the battery.
2answers
I forgot my Fondi wifi android 4.4 pattern lock
There should be an option for forgot pattern or something to that effect. Other than that you will have to completely restore the tablet
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
