I plug in a charger for one of my kid's Nabi Jr tablet, then select Power Off. However, after shutting down, a second later it restarts. How do I keep it powered off while it's charging? The other one we have always stays off when we choose "Power Off".
Walmart Product Care Plan
877-968-6391
Talk to a Human
SOURCE: Every time I try to charge the nabi xd the screen still stays black and it won't power up??
First check the charger is working. If you are using a usb cable use a short fat one (less resistance, so more power/amps).
Some times this is a batrery lockout. If you can figure out how to open the unit and unplug/replug the battery that could fix it.... Look to youtube for opening and pulling batrery.
SOURCE: We lost the charger for a few weeks when we found it now the nabi won't charge.
The charging cables are also quite finicky. If you are getting red/green flashing LED on the Nabi, be sure to turn it all the way off before charging. Also, wiggling the cable can get the unit to hold a red (charging) LED state - give it 10-15 seconds to determine if it is getting enough current to charge and the LED to settle.
SOURCE: Nabi dreamtab is stuck on Dreamtab powered by Android screen.
power it off totally , remove sims.
power up with a usb attached to your pc
it will go into debug/recovery . its kinda iffy so retry
SOURCE: Looking for the temp password for my sons nabi jr
you need to go online and register the product and if you already did,then you need to contact them for help
Testimonial: "ok thank you"
