Either the drive shaft has broken or come detached from the clutch drum at the motor end or the attachment end.
Here is the breakdown diagram http://www.mediafire.com/view/a33fr2038d5u1cr
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
