Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - 4 authors
Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
SOURCE: I HAVE A MITSUBISHI 65 INCH MODEL WS-65411 AND HAS A CODE 23
This error code shows that you have a Horizontal failure occurring. It could be a intermittent solder connection on one or more of the yoke connectors. That is the most common issue with shut down due to Loss of Horizontal Deflection. If you are handy with a soldering Iron and confident in general TV knowledge, you can repair this. If not , do not attempted it. Call a Professional. If confident, unplug the set from power, remove the speaker Grills from the front. Then remove the Center Piece of the front panel. You should have access to the front plate. Remove the 6 screws holding in on and place it aside. If you look at the neck of the left CRT', you will see a 4 pin Plug Connector that goes from the High Voltage Board up to the Yoke . You will need to use a flash light and check the solder connection under that yoke plug. Most of the time it will look like it has been arching. Resolder each of the pins. then move to the center CRT and do the same. After that, repeat it again on the CRT to the right. Make sure that each of the pins you solder are not shorted or have Solder Splashes between the pins. Plug in the set and turn on. Hopefully you will not have the problem again. Reinstall the Front Panel Access plate, Center Piece and Speaker Grills.
Hope it does the job,
Sky Assoc
