Televison & Video Logo
A
Amanda Henkel Posted on Oct 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my 2011 Sharp Aquos TV crashing?
It crashes--turns itself off--every few seconds to every few minutes--and then turns itself back on. We don't think it's a cable problem.
Claude Kayser
Level 3:
Top Expert:
  • Sharp Master 9,098 Answers
  • Posted on Oct 20, 2015
Claude Kayser
Sharp Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5060869
Points
28436
Sharp Aquos "crashing" - HDTV - Streaming Video & TVs - Tom's Guide
www.tomsguide.com/forum/24705-4-sharp-aquos-crashing
Aug 11, 2005 - 7 posts - ‎1 author Archived from groups: alt.tv.tech.hdtv (More info?) I have a Sharp Aquos 37" LCD TV(37GD6U). Every now and then I can turn it on,
Our Sharp GA864WJSA TV intermittently turns itself off for a few seconds, then turns itself on again. Please help???
Sharp Aquos problem - YouTube
? 1:41
www.youtube.com/watch?v=-EuJZ9NUf3Y
Apr 24, 2012 - Uploaded by rsimon24
So my tv is just turning off by itself, some people tell that is a software issue, others resistance hardware. Has .
My tv turns itself off and on every few minutes. I was able to update the software, which seemed to correct the problem. I turned off the tv and came back later and the problem is back
Sounds like the timer is set . Unplug it and then hold the power button in for 30 seconds . Plug it back in & power it on . Try the menu or input button . Or try tuning the TV on last after your other devices like cable , dvd ect .
Good luck !
My Sharp LE820 Aquos LED TV recently auto turn itself off, when I turn it back on, a few good 10 minutes or so later it automatic turn itself off again.
Please check that the sleep timer did not somehow get set. If it's not the sleep timer, check if the panel stays ON longer after it's been off for awhile to cool down. Possibly a heat problem with the power supply or main board.
Sharp Aquos TV doesn't work, power light is blinking at 1 blink/sec
Sounds like a fault code, ~I have found some info on it:-
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state.
hope it helps
I have a Sharp Aquos tv which repeatedly turns itself off. Can anyone help?
Try going into the menu on the control and change the power saver off, or the sleep programe turn them all off.
5helpful
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
