HP Officejet 4630 printer/scanner not communicating with HP desk top ProDesk computer.
SOURCE: Have uninstalled and reinstalled software
Are you scanning from Toolbox? Make sure the correct scanner is selected in the Settings section.
What OS is this? Try scanning from various applications.
Does the scanner react at all at any time?
Make sure you have installed ScanGear and not just Toolbox.
SOURCE: When Trying To Scan, ScanGear Message Comes Up Saying Cannot Comminate With Printer.
Make sure the "Still Image Service" is running on your system. Right-click "My Computer", select "Manage", then open "Services" applet. Scroll down to the "Still Image Service", right-click it and set its properties to "Automatic", then right-click it and "Start" it.
SOURCE: Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well, Printer Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook. You may receive some communication error messages if you are using a "PORT REPLICATOR CABLE"( USB TO PARALLEL connector). The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at [email protected] if you need further assistance.
Bye.
Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? Has anything changed on your p.c ?
A Twain error suggests a driver problem.
Have you ever wondered what Twain is the abbreviation of ?
Technology without an Interesting Name
