Question about Mackie Audio Players & Recorders
I have a Mackie sa1521 soeaker that has its thermal light permanantly on. The speaker works but is in safe mode, is there a reset, bypass or fix fir this, thanks
4 Suggested Answers
Anonymous
SOURCE:
mrwtech
Marc Wiggins
  • 59 Answers
SOURCE: SRM 450 Mackie
1)Clean the heat sinks on the amp on the back of the speaker,
2) carefully remove the amp from the rear of the cabinet and look for 'crispy critters' on the circuit board. If you see 'um, either take the amp to a service center, or go to your dealer and get him to order you a new one.
3) if you're goin' thermal, either get higher powered speakers, or tune it back a bit with these. I have a set that has run years in a dance room with no problems. If you are stretching the system to cover a bigger audience, think about another pair.
Posted on Dec 05, 2008
SOURCE: The blue light on my Mackie srm450 speaker is not
yes you can replace part.But you will need to take it to a good technician or take itto the company to avoid more fault.
Take care.
Posted on Jun 11, 2010
turinband
turinband
  • 7 Answers
SOURCE: mackie 450 thermal light on no sound
could you give some more info? what are your running into your speaker? and how exactly is it run? once we weed out common issues like switched up cables, than we can move on to internals.
which on that note, I think this is a manufacturing defect
here's a link to the schematic if you want to go poking around the circuits.....
http://www.mediafire.com/?myion3zkxn3
or
http://www.mediafire.com/file/myion3zkxn3/Mackie-SRM450 actspk.pdf
take a resistance test between D56 pin1 and Q35 pin2. thats where this issue seems to be stemming from from ones ive worked on. I have know it to be an internal track that was broken and needed to be glued back down. definitely not the first time ive seen this....
Posted on Dec 08, 2012
With the Mackie PPM608 Mixer, our passive speakers aren't working. We use CVi-252s, but I'm sure it's an issue with the mixer rather than the speakers.
Get a plug cable and work the plug in and out of all INSERT or BYPASS jacks. These get rusty and interrupt signals.
If that is a no, open up and check power supply voltages and all cable connectors, might have been vibration and something got loose...
PEACE---
Jan 31, 2016 | Mackie PPM608 Professional Powered Mixer
Tip
How to Bypass Windows Password With Ease?
Nowadays, it comes a common sense to add a BIOS or Windows password for laptop protected. Thus, a feasible advice is to create a Windows password disk in case that you forgot Windows password. But without Windows password reset disk, what should we do in order to bypass Windows password?
It's time to learn how to bypass Windows password with the following two tips and tricks.
Method 1: Bypass Windows password by Safe Mode with Command Prompt
According to Wiki, Safe Mode is a diagnostic mode of a computer Operating System (OS), a special way for Windows to load when a system-critical problem interfering with normal operation of Windows. If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to bypass Windows password in Safe Mode when you lost or forgot Windows password.
Take Windows 7 for example: there are 3 different types of safe mode: Safe Mode, Safe Mode with Networking, and Safe Mode with Command Prompt. Below is a guide on how to bypass Windows 7 password with Safe Mode with Command Prompt, which allows you to bypass Windows password with command line. Detailed steps are as follow:
Step 1. Boot or reboot your Windows 7 computer.
Step 2. Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3. Choose Safe Mode with Command Prompt in the coming screen, then Press Enter.
Step 4. Wait for Windows 7 files to load until Windows login screen comes up.
Step 5. Log in with an administrator account when you see logon screen.
Step 6. A Command Prompt appears.Type net user in the Command Prompt and then hit Enter. All Windows user account names will be listed for you.
Step 7. Type net user 'Alina 123' and hit Enter.
Step 8. The new password has been successfully reset when the command is completed successfully.
Step 9. Log on your PC with the new password.
Note: 'Alina' is your locked Windows user account name. And '123' means the new password you want to reset for the locked account.
Whenever you need to log on to Safe Mode, an administrator account password is necessary. So it is highly recommended you to write Windows password down and sotre it or creating a Windows password recovery disk before lost/forgot Windows password.
Method 2: Bypass Windows password with Windows Password Unlocker
However, if you haven't created a password reset disk and forgot all administrator account password, it's better for you to bypass Windows 7 password with Windows password reset software. These reset software allow you to bypass Windows passwordwith a USB flash drive or bootable CD/DVD. Windows Password Unlocker Professional is one of the best choice to reset or change Windows password in a while.
Go through with these steps and recover Windows password with ease!
Step 1. Download Windows Password Unlocker Professional and install it in any computer.
Step 2. Run the program and burn an ISO image file into a blank CD/DVD or USB flash drive.
Step 3. Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4. bypass Windows password successfully.
Of course, there are some other methods of bypassing Windows 7 password. Picking up a suitable and efficient one to bypass Windows password is a necessity.
on Oct 28, 2010 | Computers & Internet
Srm450 no lights
Silly question. Is the Timed Off Button jammed in?
I had one like this the other week?
Apr 08, 2014 | Mackie SRM-450 System
Mackie 450 thermal light on no sound
or
Dec 07, 2012 | Mackie SRM-450 System
When turn on:there's a blowing sound from the speaker...I wonder what component might broken from my SRM450 mackie speker??? Thank You
The actual cone it self... There is no permanent fix for this you can try to use clear nail polish on it by removing the grill and applying polish to ripped portion of the speaker
May 04, 2011 | Mackie SRM-450 System
Cuts out ofter 1 hour good loud usage. thermal and limit lights DO NOT illuminate. (They DO work, as Ive seen them on in the past) Jon
probably overheated capacitor somewhere in the unit. You can use multi-tester or capacitor tester to find fault.
Jul 06, 2009 | Mackie SWA1501 Subwoofer
Mackie srm450 not making any sound at all
It sounds like the thermostat didn't shut the speakers down before they were damaged. There is probably a very fine wire leading to the speaker coils which is burned/broken. Fixing this broken connection my solve the problem unless the coil itself is damaged.
Another possibility is that the crossover circuitry in the speaker cabinet is damaged from overheating.
Sounds like you need a service tech to look at the bad speaker, unless you want to tackle the job.
Apr 22, 2009 | Mackie SWA1501 Subwoofer
SRM 450 Mackie
Oct 04, 2008 | Mackie SRM-450 System
159 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
PickyPrick
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
