Mitsubishi WD65737 65" DLP TV Logo
b
bill church Posted on Oct 23, 2015
Why is picture 1/3 down from top and 3" in on right side is a little darker?
Looks like the mirrors not lined up right
Gary Camp
Level 1:
Scholar:
New Friend:
  • Contributor 35 Answers
  • Posted on Oct 26, 2015
Gary Camp
Contributor
Level 1:
Scholar:
New Friend:
Answers
35
Questions
Helped
6564
Points
60
Did you move or bump the TV? That can cause misalignment. Did anyone fool with the setup? Get the manual and run through that again. Did you change input source (IE new DVD player, etc)? There is a setup (usually in menu) for slight adjustments to picture in most TVs, like on computer screens adjustments if you ever have done that. RTFM
Panasonic 37 inch lcd tv
Check its back light CCFL lam of that side, which look darker. Replace it.
3helpful
2answers
Mitsubishi dlp tv picture is getting darker
One of two possible issues:
1. Lamp is nearing end of life and may dim just before total failure.
2. A few of these models have 2 mirrors(check with Mitsubishi to see if yours is one) A large mirror in back (never gives a problem and do not try to clean it. Some idiot in these sets used a small mirror inside that the optical unit shines the picture into (wedge shaped mirror and small) and it is facing up----the fans intake air from the front of the set around this mirror--it gets coated with lots of dust---Picture can loose up to 70% of its brightness and clarity if that mirror is dirty--looks like 20 year old set .
If you do not wish to check with Mitsubishi GOOGLE THE MODEL NUMBER with "mirrors" to see.
If it has 2 mirrors I can tell you exactly how to get at it.
SD TECH
What is causing 2/3 of the screen to be darker than the 1/3 (right side)? in addition, the darker 2/3 side color does not match with the correct (right side) colors. i have recently replaced the lamp and...
Is there an powerful electrical device kept very close to the affected side of the TV? If yes then please move it to a greater distance. This device may be affecting the display.
Just tonight we were watching TV and the screen got darker. Picture is still fine, just got darker, on some channels the top and bottom center bow in toward the center a little, easy fix or a lot of...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The top and right side of the picture have a darker picture like in a shadow. about 3 in on top and 3 inches on the right
Richard, I've heard it's a mirror issue. I've got the same problem, but mine started in the upper-left, moved both to the right and down.
Let me know if you found a solution at [email protected]
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
1helpful
2answers
Convergence
If the CRT Projection television has several colors or one that arent lining up, if due to an impact - you may have a broken mirror, if just happened all by itsself it may be a convergence issue, either issue is repairable, probably for around $400-$500. I dont recommend taking a set like that into the shop as sometimes transport can break/crack a mirror or throw convergence off.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
