If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: want to program Dish remote to run sansui tv
SOURCE: I am looking for Internal diagram - Service Manual for Sansui TV
I AM LOOKING FOR A CIRCUIT DIAGRAM OF A TV MODEL E2999 .THE COMPLETE BOARD OUTLAY AND DIAGRAM
SOURCE: TV MODEL :SANSUI HARD ROCK
Hi The problem of your teevision is what we called the vertical line problem.The problem is in the vertical section of the board.There are many of cause of that problem.First is either loose connection,the circuit at the vertical section have cold solder so its need to resolder using soldering iron.Second,it maybe no vertical supply,its better to check the 12 volts dc supply of vertical ic output.if thers no supply in the ic,there a open resistor near the flyback.try to replace.Third if theres no loose connection and have a voltage supply the problem is either leaked capacitor or deffective vertical ic output. Commonly in that problem is the loose connection,try to resolder the verical section.
SOURCE: my sansui 21 inch tv. model no. CTVSFS21SDACUS can i have the service mode for this tv
Visit this site. It has details about access service modes to most brand of TVs. Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about how to enter into the service mode to many brand TVs, and how to adjust data values. In name [Electro-Help]
electronicshelponline(.)blogspot(.)com
