Panasonic Viera TH-50PX80U Plasma TV Logo
Paul Ronan Posted on Oct 24, 2015
Trying to get xfinity x1 remote to run tv, looking for remote code. panasonic remote n2qaybooo221
2 Related Answers
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on Dec 23, 2011
SOURCE: TV code for Panasonic TC-P50S30
Check the dish network website or panasonic web,,support,,,,they should have or website of the brand of remote u programing ,,,goodluck
shane vanput
  • 133 Answers
  • Posted on Jul 04, 2016
SOURCE: I have a I got an X1 Xfinity cable Xfinitybox remote control to my Panasonic and I need the code to operate my television volume
003,051,055,062,070,148,170,171
What are the codes for xfinity remote to control Panasonic TV/TC-L42U22
  • Panasonic HDTV Codes :1140,1169,1170,1194,1233,1234,1331,1336,1410,1417,1442.
  • Panasonic TV Codes: 1003,1010,1049,1053,1096,1123,1152,1231,1289,1292,1295.
  • Panasonic DVD Codes : 2031,2066,2075,2076,2104,2105,2106,2111,2151,2153,2154.
More items...
Remote Control Codes For Panasonic TVs, DVD, HTS
2answers
Channel 1 will not mute when button is pressed. all other channels are fine
press it hard and try to vibrate the button sometimes it makes bad contact or random connection. Also try different remote or ask you cable provide for replacement.
How do i pair my tv to infinity.remote
To Pair an Xfinity Remote (With a Setup Button)
  1. Make sure the remote batteries are installed and your TVand TV Box are powered on.
  2. Set the TV input to the input connected to the Xfinity X1 TV Box.
  3. Press the Setup button on your remote until the LED at the top changes from red to green.
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
2answers
Can I program a GE 24116-V2 universal remote control to operate a Xfinity X1 Cable box ?
This remote control have no setup codes to Xfinity. If you wish to get more details visit the site linked here. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://homenol.blogspot.com/ Setup procedure and set up codes for many popular brand remote controls are given.
We cannot find closed caption
Do you have the X1 service? If yes, then hit Xfinity button and scroll over to settings (looks like a gear to the right of "Apps". Then go to "Device Settings". You'll see it there.
Remote codes for the bose solo
remote code for comcast xfinity x1 dvr. the codes that they had me try when i called did not work. Has anyone found any codes that actually work?
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
