Generally the COOLPIX line of cameras does not have a lens that can be removed or changed. Does this answer your question?
Some of these cameras have a lens cover that is like an external shutter. To use these cameras you must expose the lens, usually by moving a small sliding piece that is next to the lens, either up or sideways.
Table I shows a brake down while oil has been changed this week and stay mesage is *** and the beep every 1 klm only fair Doige please This is what the translator came up with
if the hardware is recognized but it can't read anything then it maybe hardware failure. I suggest get it checked. Most dvd drives with laptops comes with the driver included with the OS so I don't think that driver's are your problems. if your problem is just recording try to clean the lens by buying one of those lens cleaners.
Take your camera and carefully look at the lens side of it. Does the lens look slightly out of center. Sort of pointing very slightly the wrong way. If it is you've given the lens a knock while it's been extended and put the complete lens barrel out of alignment. Please don't try what I've seen touted around the Net and bash the camera lens down on a table, this will make the whole thing completely unusable. The camera needs stripping down completely and the lens either realigned or worse, completely replaced.
The other problem it could be is a piece of grit or sand jammed between the lens elements or the lens and the camera body. Again a strip down job to free the jam.
Just make sure the batteries are at full charge and in good condition if they are getting a bit old try a brand new set of High quality alkalines and see if things start moving then. Quite often the camera may switch on but simply doesn't have enough power to drive the lens. Try the batteries first, you could save a packet.
je viens de resoudre le probleme sur mon pentax E70L avec un simple aspirateur domestique,a l'aide du tuyau le plus fin, en realisant un nettoyage minutieux, tout autour de l'objectif, (sans rien demonter, evidemment!), ensuite le code lens error a changé, puis j'ai continuer a ouvrir et fermer l'appareil, a tenter de changer les options "scene", et l'appareil ne s'est pas refermer !...et j'ai pu refaire des photos!...soulagé!...l'appareil n'avait pas 2 mois!..mais rappelons nous qu'il n'aime pas le sable!
j aimerais si possible que vous me répondiez en français s.v.p A la première installation , tout allait bien et les couleurs y étaient toute ... par ignorance , dans la fenêtre Propriété de Document Kodak 5300 AIO dans l'onglet général, à la question Mes Préférences . j'ai pris pris un des 2 choix et je me souviens pas quoi, et a partir de là , les couleurs on changé. ce n'est pas grand chose, mais je ne comprends pas pourquoi les couleurs n'ont pas d'éclat le pire c'est la couleur rouge c'est très décevant C'est n'est pas la première imprimante que j'aie, sur la page de démonstration , le lettrage est gris pâle , et le tour des yeux sur la photo des enfants est blanc..... et lorsque que je lui demande un diagnostic il n'y a rien s'écrit sur la page
