SOURCE: My m20 pentax is on green mode & powers off after powered on
Do you want to disable the green mode? Is that what you want to happen?
If so, all you have to do is to press the Green button near the four-way controller.
SOURCE: how do i remove the green mode from my pentax e40
If you press the green button again it cancels green mode.
If you want to select a different mode press the down arrow on the four way controller when you are in capture mode.
That has icons for different modes like landscape or program mode.
Move to the icon you want by using the 4 way controller then press ok.
The button with a triangle on it that is above the 4 way controller
switches between playback and capture modes.
SOURCE: How to cancel
The Green mode locks out the user from the camera menu. To cancel the Green mode you must press the Green button again.hope this helps
SOURCE: Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
SOURCE: My pentax rs1000 keeps taking
Do the pictures appear green only on the screen or do they look the same after transferring to computer as well? If yes then it is definitely an issue with the CCD image sensor of the camera. Get it replaced by an authorized technician and your cam will be back to normal
