I need help to install a binary file enabler. I have not been able to play any games for four months.
I have tried every helpsite that Bf has. I cannot open my games. I had trouble on pogo and it was the same thing wrong.It comes up with error but no code.
This is because the game has not been cracked. Usually in the torrent file there should be a crack for the game. You have to run this crack to enable you play the game. Check the downloaded folder and there should be a folder or an executable file there which can be used to crack it. Take a look at it and run this file. After running this file it should work properly without asking for any disc. Hope this solution has been helpful?
i think you might eather have A. have terrible cheats B.something wrong with your ds or C. your game is screwed up sorry mine did the exact same thing ; - )
Reupdating your system firmware via USB Device (download the update from Playstation Website)
Restoring your system (don't forget to backup all your important files !!)
else,contact Sony support centre for possible hardware issues checking, certainly it's a problem with your blu-ray reader and, if it's not covered by warranty, you will need to buy a new reader
Update your directX. you can get the latest updates at microsofts website or go through google and type directx runtime. Download the redistributable file. it better.
Secondly go back to the website where you got the game for the installation manual and requirements. if your systems meets all the requirement and the problem still persists then uninstall it and follow this procedure:
right click the installation file e.g game.exe, click run as administrator. follow the installation instructions.
after installation right click the game program and also click run as administrator.
On the game settings, enable Hardware accelerators and use directx if these options are enabled in the game settings
goto properties of the file and in the compatibility tab enable "run this in compability for" and select the OS in which it used to work well... this might help....
u need newsleecher free dl of net alt.binaries.xbox360 look 4 number at side of game dl all the same numbers burn as image in record now max stomp will play no prob
