My whirlpool cabrio washer Mod. # WTW6600SW2 SER. CU 2773217, Type :580 gives an error F50, and 5d (I have never used anything but HE detergent and fabric softener in it). It is about a year old. The problem appears to be it not spinning. It drains the water, and looks like it wants to spin, but doesn't. Is there a part I can replace or do I need to call a repairman? Thanks in advance.
F then 50 flashes when the motor rotor
position sensor (RPS) senses no rotation.
➔ Does basket turn freely? If not, make sure
bottom shipping pack has been removed.
Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control,
by analyzing drag on the basket, detects a
suds-lock condition, and is steady on while the
control then runs a mini-clean out cycle. If the
clean out cycle is unable to correct the
over-sudsing problem, the cycle ends and Sd
flashes in the display. This may signify:
➔ Load is bunched or twisted around agitator.
➔ Excessive detergent usage.
➔ Basket cannot engage during drain step.
➔ Mechanical friction on drive mechanism,
not allowing basket to engage.
Aug 21, 2009 - 10 posts - 5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
