Inking Motor Lock
• If excessive current is detected 0.3 seconds consecutively after
the Inking motor is activated. This problem will need to be addressed by disassembling the drum and checking the motor and the ink pump. If locked, clean and lubricate.
Hi Foday
Check this PDF
http://www.scribd.com/doc/39720943/Riso-Cr-Manual-Service#scribd
SOURCE: error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
