Boating Logo
Lori Lorentz Posted on Nov 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove the twist grip on 15hp evinrude outboard motor?
How to remove the twist grip on the motor replacing throttle grip
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Nov 01, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061613
Points
28436
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
87 evinrude tiller style outboard throttle adjustment is too tight and near impossible to adjust.
In The Under Side Of The Tiller Is A Screw Loosen It Off That Is The Throttle Tension er, On Some Models The Front Portion Of The Grip Rotates And Tensions The Throttle
Mar 07, 2013 • Boating
Evinrude 15HP Outboard - Vent Holes
have a problem , check impeller pump
Sep 07, 2017 • Boating
2answers
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 • Boating
Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Aug 28, 2009 • Boating
3helpful
3answers
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
