Televison & Video Logo
tabitha Lynn sowards Posted on Nov 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 27inch Philips flat TV that when its pluged in the light is solid red and TV won 't turn on
Claude Kayser
Level 3:
Top Expert:
  • Philips Master 9,098 Answers
  • Posted on Nov 01, 2015
Claude Kayser
Philips Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063675
Points
28436
Common TV Repair for Emerson, Sylvania, Philips, Magnavox
? 5:35
www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
Top most common LCD TV repairs for Emerson, Sylvania,Philips, ... my tv wont turn on neither the led ...
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Mar 21, 2008
SOURCE: philips 37 flat screen
I'VE WORKED ON A LOT OF PHILIPS FLAT SCREENS AND ALWAYS NOTE ,WHEN THERE ARE PROBLEMS WITH THESE SETS--THE RED LED WILL BLINK GIVEN YOU A CODE FOR TROUBLESHOOTING..EXAMPLE---ONE L0NG BLINK,4 QUICK BLINKS--BAD AUDIO BOARD,,,SOOOOOOOOOOO,CHECK YOUR BLINKS,HA!
Anonymous
  • Posted on Dec 12, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Jose Garcia
  • 453 Answers
  • Posted on Apr 14, 2010
SOURCE: Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Anonymous
  • 304 Answers
  • Posted on Apr 16, 2010
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Anonymous
  • Posted on Sep 27, 2010
SOURCE: Hi we have a 42in philips matchline flat tv. When ...
mine is doing the same.... any solution to fix this problem?
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
3helpful
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
My philips tv don't turn on it go to green then to red
TRY UNPLUGING AND PLUGING BACK IN. MINE DID THE SAME THING AND AFTER 15-25 MINUTES IT'LL COME ON. EVENTUALLY IT WON'T COME ON AT ALL, THIS IS WHERE I'M AT NOW
4helpful
3answers
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
1helpful
Trying to connect nintendo wii to philips tv
If I have the right manual you should connect the wii cable from the package to th backside of the tv. You will see four pluges. Choose with VGA you want to use, this is not important. Use the cable from the wii and plug in two of three pluges, you must match te coulors. If you have a cable box installed you will probably have scart (a big cable with a large head) connect this and it would run smooth. You can also connect the three pluges from the cable to your cable-box, use the red, wihte, and yellow pluge.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
