Question about Pantech Cell Phones
How do reset the time - Pantech Cell Phones
  • 652 Answers
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Posted on Nov 02, 2015
Anonymous
SOURCE:
Reset lamp time
The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the usage time of the lamp. Pressing the RESET button on the remote control or the ? button of the projector displays a dialog. To reset the lamp time, select the RESET using the ? button. RESET ? CANCEL • Please reset the lamp time only when you have replaced the lamp, for a suitable indication about the lamp.
May 13, 2015 | Hitachi CP-X505 Projector
E8 error on mp210
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
May 30, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Error 27
Hello.
Here's what you need to do;
Make sure the printer is powered off but connected to a power source, then press the Power button while pressing and holding the Stop/ Reset button. And turn on, press the Stop/Reset button two times while pressing and holding the Power button. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Jun 17, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Alarm and ink buttons all orange flashing E and 3 What do i do? first time both inks low cannot replace as do not stop in the middle holding down reset button turning printer on and off
You need to reset the Printer
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jan 05, 2011 | Canon Office Equipment & Supplies
CANON MP160 PRINTER SHOWN ERROR E27, HOW TO RESET THE COUNTER?
Follow these procedures to reset the counter.
and holding
2) When the Power is lit, press the Stop/Reset button
move into a
4) When the on/off lights in green, press the
Stop/Reset button 4 times, the specified number of
alternately in
button pressing
5) Turn off the printer.( it must be turned off)
then turn it on again.
Aug 31, 2010 | Canon PIXMA MP160 All-In-One InkJet...
It keeps flashing E and then 3. what do I do?
MP150/160 resetting errors
Do it : 3 times Orange EEPROM reset
button pressing
procedures below.
procedures below.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cant use
Try this steps Mp150 Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Jul 07, 2009 | Office Equipment & Supplies
My printer ink absober was full. my printer display e27 code. what can i do?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-9
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How do I fix or reset ink absober full problem on canon ip4600
Reset procedure
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
Mar 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
button pressing
procedures below.
procedures below.
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Cell Phones Logo
147 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
rebecca curry
Edward Greene
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
