CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
CHECK DEFROST TIMER, CHECK HEATING ELEMENTS @ EVAPORATOR. BUT SURE MUST BE THE DEFROST TIMER. TO CHECK TIMER, IF IS MANUAL U CAN USE A SCREW DRVER TO TURN IT, IF IT DOES NOT DEFROST IT`S THE TIMER. NOW IT IF TIMER IS A ELECTRONIC TYPE, THAT CAN`T BE TESTED MANUALLY. REPLACE IT TO PRENET ICEBUILD UP @ EVAPORATOR.
There can be three issues: defrost heater (part WR51X10101), defrost thermostat (part WR50X0122) or control unit (part WR09X0122).
Check the heater first, use the tester, it shoud measure '0' (resistance 26 Ohm - it was 'infinity' in my case, i.e. it it was the culprit). You can buy it from AP Wagner (http://www.apwagner.com/).
If that happens again, replace control unit, then try thermostat.
hope it helps.
