Siri Assistant Logo
A
Alejandro Posted on Nov 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I get Siri on my iPad - Siri Assistant
Erin Wood
Level 3:
  • Siri Master 652 Answers
  • Posted on Jan 04, 2018
Erin Wood
Siri Master
Level 3:
Answers
652
Questions
0
Helped
211103
Points
2583
Https://support.sprint.com/support/tutorial/Turn-Siri-on-or-off-Apple-iPad-Air-32GB/WScenario_542_50660_771_en_1361-dvc7820010prd
-From home screen, tap settings
    -With general selected, tap Siri
    -Tap Siri switch to turn feature on or off
    -When prompted to enable Siri or disable Siri, tap preferred option
    -Siri is now enabled or disabled
How do I get Siri on my apple ipad
Press and hold the Home button. Siri is enabled by default on all devices that support it, so usually you can just press and hold the Home button to start the Siri interface. The Siri prompt will appear, and you'll be able to speak your command or question.[1]
  • If Siri doesn't start, it may be disabled or your iOS device may be too old
Say "Hey Siri" if your iOS device is plugged into a power outlet. When your iOs device is plugged in, you can say "Hey Siri" to launch the Siri interface without pushing any buttons.
  • The iPhone 6s, iPhone 6s Plus, iPhone SE, and iPad Pro allow you to use "Hey Siri" without the device being plugged in.
  • If "Hey Siri" isn't working, it may need to be turned on.
Ensure your iOS device is compatible. Siri does not work on older iOS devices. The iPhone 3GS, iPhone 4, iPad, iPad 2, and the iPod Touch 1st-4th generation do not support Siri. Even though these devices may be able to install a version of iOS that supports Siri, they won't be able to use it.
  • Visit support.apple.com/en-us/HT201296 for information on identifying your iPhone if you're not sure.
  • See Determine an iPad Model / Version for information on determining what model iPad you have.
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I'm available for longer billable discussions at https://www.6ya.com/jim_8a00509cb5f5d7e2
If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
I can't find Siri
To use Siri, simply hold your thumb or finger down on the power button. You will hear a double tone when it is open. For Siri settings, go to Settings, General, then check for Siri either in the left hand menu (IOS 10) or on the right side menu.
When I try to engage Siri she says she cannot make the connection and I should try again later. I have iOS 10.0.2 installed. I have shut it off and restarted but the problem remains
Siri troubleshooting: Siri's not working at all on my device. Which iPhone/iPad models can run Siri? If Siri isn't working for you, the first thing to check is your model of iPad or iPhone - older devices can't run Siri, even if they update to a newer version of iOS. Siri is available on the iPhone 4s and later, on the iPad 3, iPad 4, and all iPad Pro, iPadAir and iPad mini models, and on the 5th- and 6th-gen iPod touch models. Plus the Apple Watch and 4th-gen Apple TV, of course Siri troubleshooting: How to turn Siri on If it's not working at all, Siri might be switched off. Go to Settings > General > Siri and make sure the top slider (next to Siri) is on, and green.
When done with siri, what do i do. no back button. ipad air
When you are done with siri, you hit the home button. Itll bring you back to where-ever you were when you activated her.
2helpful
2answers
Is Siri not on the original iPad?
Siri is not on the original iPad, because apple only put it on the iPad 3 gen and up. Most likely due to the face they want you to purchase a newer iPad, so they can make more money, more information can be found here. http://en.wikipedia.org/wiki/Siri
How do I turn on Siri on IPad 2?
I don't think Siri is on the iPad 2.
How do I disable Siri, please on my iPad. I have follows the usual steps that do not work. A black outline box circles all commands, so Siri refuses to run off.
Restore it by holding down home key and top button until apple returns to screen. If that doesn't work back it up and restore it as new. Don't turn spotlight or Siri settings on ever, wastes data and tracks your cell
Top Siri Apps Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
john h
Are you a Siri App Expert? Answer questions, earn points and help others
