LG WM1814CW Front Load Washer Logo
Anonymous Posted on Jul 13, 2009
I found water under the washer. I took the top
I found water under the washer. I took the top off and and found water leaking from the top of a white switch (??). The switch had a hose that was connected to the prewash tray. It also has a blue H plug going into it. It leaks while washing and even when the washer is off. I am not even using the prewash cycle when it is leaking. What do I need to replace?
Anonymous
Level 3:
  • Master 583 Answers
  • Posted on Jul 13, 2009
Anonymous
Master
Level 3:
Answers
583
Questions
0
Helped
261063
Points
1667
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Water leaking from vent hose outlet
Does your User Manual say anything about this being likely to happen?
Sounds as if there is a throw-up of water into this hosing in the spin cycle or some such thing?
Do check your water hoses are tightly screwed. I have seen cases where fine jets of water spray into odd places which cannot be seen when the machine is backed to the wall.
Poppa
http://www.cdbaby.com/cd/poppamadison
2answers
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
2helpful
Water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
1helpful
Water leaking from white plastic peice under washer
If this piece had 2 hoses attached and slides onto the motor, then it is the pump. you will need to replace it. Part # 3363394 available both new (27.99) and used (9.99) from timerking.com Hope this helps!
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
