Honda 2003 Pilot EX-L Logo
S
Stephanie Posted on Nov 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver door lock won't respond to remote, but key in lock won't turn either. Would both be fixed with a new actuator?
Jay Plesset
Level 3:
  • Honda Master 2,942 Answers
  • Posted on Nov 06, 2015
Jay Plesset
Honda Master
Level 3:
Answers
2942
Questions
Helped
667504
Points
9879
More likely, there something frozen or broken in the mechanism you can fix. If the lock mechanism is frozen, a new actuator won't fix anything.
1helpful
Sometimes Car does not respond to remote control . some times drivers side door button come up half way. if i use key in door all buttons popup. but key cannot be removed all door lock up to pull key
4 things to consider.
1. Does your key fob transmitter need a new battery.
Replace battery.
2. The remote module is faulty.
Replace module.
3. The lock actuators may have worn out.
Replace actuators (it may only be 1 or 2 of them)
4. (Most likely) All the associated wiring may need checking for earthing problems and /or breaks. The spade type connectors often rust inside the door.
(But if you can, pull each lock up by hand to see if its smooth. If you have to put real effort in to pull it out then the actuator is the problem)
Good luck...
The driver door won't lock
if you can manually lock it with key,and from inside the car also
then there is a bad relay
if you can lock it with key but not from push button on driver side door then the actuator is bad
2answers
Doors won't lock, thinks key in ignition
Troubleshooting is required to inspect few parts.It can be issue with ignition switch.Its not getting off.Or issue with sensor or wiring.Or its faulty lock itself.Click the link below and follow the troubleshooting:----Driver Door will not lock or unlock with Key or Remote? http://whatisbyme.blogspot.in/2012/05/1998-toyota-landcruiser-driver-door.html
Driver side door will not lock or unlock with Remote? http://technoanswers.blogspot.in/2012/04/2009-toyota-tundra-driver-side-door.html
Central locking not working ? http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
2answers
Central locking working passenger door won't open
get remote checked wires might need re soldering or replace remote with new one. Cheapest place to purchase one is at a key cutting place or lock retailer.
2answers
Must use the key to open the door. Once it has been unlocked, the remote will work to lock and unlock the doors. After a short period of time the remotes will not work again and must use the key again to...
Hi and welcome to FixYa!
Looks like that you have a faulty door lock actuator that's why it's not responding with the remote. If the actuator is faulty it tends to trip, sometimes will open sometimes won't. Using the key will surely lift the locks upward and by then the actuator can work again.
Have the door lock actuator replaced and you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
2helpful
4answers
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
The driver side door power locks
inside the door there is an actuator and the rod has become disconnected from actuator to lock mechanism and randomly hits, you have to pull interior door panel and look by door lock inside and look for loose rod and reconnect
1helpful
2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
13helpful
2answers
2003 Honda Pilot Rear door lock not working
I have a 2004 honda pilot.The passinger door and the back door behind the driver seat will not lock or unlock with remote or with door lock switch,What can I do to fix it?
4helpful
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Top Honda Heating & Cooling Experts
Paul Carew
john h
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
