Plantery gear never stops under load just slips, so I dont think its a sheared key, or worn gear. From what I have read online its the clutch is most likey out of adjustment
SOURCE: Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
SOURCE: Hobart A200
When you say lag and catch up. This may not be a issue. I have seen this with dough and a spiral hooks on all sizes of Hobarts the hook and dough get in a position to push the hook forward and the drive gears catch back up the hook. in fist gear on the 20 quart this is common for sure. but its normal. if you have a real slip from a sheared key it will not take long to where you can hold the planetary shaft with your hand and stop it. another slip that might be possible is if your mixer has the first generation worm shaft gear Assembly. when it is worn out it will slip you. this is the shaft that drives directly off the motor. you can tell if it's first Gen by it has a large spring on it. the tow later versions are all keyed to the shaft no chance to slip unless a key shears.
Michael
SOURCE: Hobart A200 noises
Hi, here is my opinion: 1) your planetary, or attachment hub is making the noise as it goes around, and there is grease in the gear ring that keeps it lubricated, it may be as simple as removing the planetary grease ring ( the chrome ring), and taking loose the bolt and lowering off the hub and cleaning the old grease, and installing new, reassemble in reverse. You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing. How far you want to go is up to you.
For your other problem, I have seen the brass clutch bearings stick on the main shaft in the transmission, causing the planetary to momentarily speed up, or to maintain a wrong speed ( 2nd or 3rd) when set to first, but that would require full disassembly of the transmission. Best left to someone who has done it before, but if your inclined, go for it, but get a part breakdown first, or take pics as you go. Hope at least some of that helps, and thank you.
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
SOURCE: V1401 slips in all gears; what to adjust?
Take the top cover off,in front of you is the brake.Turn the mixer on and you will see it spin (put it in 1st gear),stop the mixer.on the right side you will see a pin that catches the brake flange,if its worn you can replace it,if its not worn then the brake needs adjusting as it acts like a clutch.Let me know,im a hobart tech band repair these units often.
