Cameras Logo
d
denver cupps Posted on Nov 07, 2015
New battery but power wont turn on with battery but charging red light is on
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jun 11, 2007
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
A
Anonymous
  • Posted on Oct 23, 2007
SOURCE: Camera will not charge the battery
This isn't the best soulution but it worked for me. I cleaned off the contacts on the battery and when I placed it back in the camera I put a small piece of a thick rubber band under the door and closed it. This forced the battery farther onto the camera terminals and I was able to get a full charge on the battery.
Anonymous
  • 431 Answers
  • Posted on May 29, 2009
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
Anonymous
  • 5 Answers
  • Posted on Jul 08, 2009
SOURCE: Charging lights turn red and green...But camcorder will not power on
All right if you have the same problem that i had what you need to do is take the battery out the take the memory card out the put the battery back in then try and turn it on if it works then put the memory card back in and it should be fixed
david
  • 244 Answers
  • Posted on Jan 03, 2010
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
My camera wont turn on after being charged all night and day. i checked it repeatedly to see if it was done charging and all i got was a blinking red light the whole time. it wont turn on!
The battery itself could have gone bad. If the cells within the battery are damaged, it can refuse to charge or power the camera, which would explain the blinking red light.
You'd need to purchase a replacement lithium ion battery.
Vivitar 8010 camera wont turn on, but has power, red light is on.
I suspect you battery has died,this happened to me the other month.
Easily fixed by buying a new battery, got mine off Ebay £7.99
3helpful
2answers
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
My bold wont turn on. when charging, red light goes on and off
did you try the car charger,wall charger might be faulty,if that does'nt pan out,might need new battery
1helpful
When i try to power on my son's DS Lite, the red light is on, and both screens power on for about 2-3 seconds max and then the system shuts off. It also wont charge when connected to the wall.
You may need to get a replacement battery pack when the battery is below 30% the light will turn red, the battery requires 4 hours to charge, and when the battery is fully charged the amber colored light will turn off. If you still need to purchase a new battery contact nintendo cust serv at 800-255-3700 or you can order online at nintendo.com You will need a #00 philips screw driver to remove the battery cover, install the battery with the 2 tabs in first, close compartment and allow battery to fully charge before use. The average battery will last for about 500 charges. Hope this helps
1helpful
Wont turn on, wont charge
REPLACE THE BATTARY........... THEN NOT WORK TRY NEW BATTERY THEN UNDER WARRENTY CONTUCT SERVICE CENTER
Power light is red
Get a new battery.. that one is shot.. it wont take a charge thats the reason bud
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
