I need to find codes for a sanyo tv
Nesecito codigo para control remoto URC-3021B00, PARA TV, CABLE Y DVD. SINO PARA TV. NOMAS.
GRACIAS
[email protected]
NECESITO LOS CODIGOS PARA ACTIVAR MI TV MAGNAVOX CON EL CONTROL URC 3021 BOO ,
OJO
MI TV TINE PARA DVD ,PARA VHS Y Y TV NORMAL
PERO ME INETERESA LOS CODIGO PARA ENSENDER ,APAGAR Y DARLE BOLUMEN O SEA OS MAS SENCILLO
Sanyo 0154
Toshiba 0154, 0156, 0060, 1356, 1656,
1704, 0650
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
here is yor manual
http://www.ofausa.com/remote_manual/CTGA...
Here are your codes
http://www.ofausa.com/list_codes.php?db_... 3021
If you dont see your product try a code search funtion. If this does not work your remote might not support your unit.
SOURCE: how to program i have code for urc-4021
here is the manual to the remote. start on page 8
http://www.oneforall-na.com/remote_manual/CTGAE4P%204021%20anual%20booklet.pdf
Good Luck and Please Rate FixYa!
SOURCE: Sanyo TV Code not Avablable
the codes to operate a URC 1030 or URC 2010 to operate a Sanyo TV is a 5 digit code: There are three codes thaty should work, they are:11413, 11423 or 11341.
Good luck.
I Need The codes for Toshiba tv on URC-3021B00 Remote Control
Have lost code and instructions to the remote control...please help.(URC-3021BOO)
need sanyo tv codes
I need a code for my Sharp TV?
I need the codes for a philips universal remote, CL019, so I can program it for a sanyo tv. I e-mail is [email protected]. Thank you!
need codes
DESEO OBTENER LOS CODIGOS DE CONTROL REMOTO ONE FOR ALL URC-3021BOO
i need to program the remote to my sanyo tv
I can't program the remote to my Sanyo TV
I need the program code for a Philips universal control for a 25in color Sanyo, can anyone help me out. My kids got a hold of the of the control now it won't operate the TV. If anyone can help I would appreciate it. Thanks ,
Dave
i have a sanyo tv and a technika universal remote for it but can't find the codes anywhere,would really appreciate any help
tengo el control pero se desprogramo mi televisor que es marca daewoo y necesito los pasos y el codigo.
I need the codes to a sanyo t.v. so ican program it to my access 4 one for all remote
the code for urc-3021 Sanyo TV
i lost my code for programming my sanyo tv with my one for all remote urc*3021
