My brother printer is giving us an error that says "100% Stacked" what does that mean?
It means that the printing order for the memory for the printer is full
go to control panel , go to printers and hardware , click on printer right click and it will show a section see what is printing
high light each line and delete that takes away the priority of the stack until there is nothing left to print and the printer should again print at the next selection you make
How the program works is this
there is a small memory in the printer and a large one in the pc
when you have data that is to be printed, the pc sends the data until the printer memory is full at which stage the printer starts to print. new data is sent as memory space becomes available until the document is printed
when different data is requested to be printed or there is a hiccup in the process the pc looses the priority in the print list ( page number or new document)and so backs up that memory and becomes blocked
by going into the pc in the printer hard ware and deleting the printing waiting to be processed your are unblocking the process and allowing the pc to again move data to be printed
Sorting copies using the ADF
You can sort multiple copies. Pages will be
stacked in the order (1, 2, 3), (1, 2, 3)
and so on.
1 Press (Copy) to illuminate it in
green.
2 Load your document.
3 Use the dial pad to enter the number of
copies you want (up to 99).
4 Press Options and ? or ? to select
Stack/Sort.
Press Menu/Set.
5 Press ? or ? to select Sort.
Press Menu/Set.
6 Press Start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
If you need more help come back.Post /
thumbs / testimonial are
welcome!
