I believe what is happening is your freezer is not defrosting properly and your auto damper is opening just enough to keep the temperatures safe on the fresh food side. look into freezer and the rear wall. Is frost building up on the rear wall? If ye then this is a defrost issue and you will need to unplug and manually defrost with a hair dryer. Don't be afraid to remove the rear panel in freezer so you can see just what happens when defrost is not taking place. I think it is possible that you have a model LSD2615HEW but you will need to confirm before asking for parts. Inside the fresh food compartment and behind the control panel the model LSD2615HEW for example only has a Click Here=> 12002495 Adaptive Defrost Control Board I say example only because I had to assume your model number. This board is the most likely reason for this problem. Sometimes you may see burn marks on one side of board but not always. Click Here for location=> LSD2615HEW Controls and part 12 in photo is the ADC or 12002495 Adaptive Defrost Control Board The only other cause will; be a defective defrost heater or defrost thermostat. The defrost heater is=> 67004188 Defrost Heater Assembly testing of the defrost heater is also in a short tutorial on this same page. Then finally it is always a good idea to replace the defrost thermostat while inside replacing the defrost heater if need. Part number for the defrost thermostat is=> 67004757 Defrost Thermostat and can be found here=> LSD2615HEW Freezer Components If you have any questions I will be here to answer them for you, If helpful please rate this solution, Thank You, Sea Breeze
