Question about Maytag Atlantis MAV6000 Top Load Washer
Describe your Maytag Atlantis MAV6000 Top LoaI
Maytag Alantis washer. It agitates. During the spin cycle it drains and rinses but the tub does not spin. The belt is fine
  • 25 Answers
Drive unit faulty/or faulty lid microswitch
Posted on Jul 13, 2009
6ya staff
SOURCE:
Should water back up into the tub upon spin completion on maytag atlantis
No, If water is coming back, the sewer is cloged up or is a big posibility that the washers transmission is not spenning at all. it may sound like is agitating during the wash and spinning during the rinse. To check it, put soap inside the drum if it doesn't get disolved after the cycle is done. The transmission needs to be replace. Is costly you may want to shop for a new one.
Jul 19, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
MAV6250AWW Alantis washer Fills Agitates but does not drain rinse or spin unless I spin the knob while in the off position to the desired function
I would suspect the timer needs replaced since it works if you manually advance it. If this helps, please rate my answer. Thank you.
Jan 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
478 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
