1. Power off the printer. 2. Hold down the green GO button, and power the printer on. Keep holding until all three control panel LEDs are lit up and stay lit. 3.Press the down arrow until you get to COLD RESET, then press the green GO button.
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
The error message is due to the lens issue. the lens might have stuck due to moisture condensation or dust. It may require service to resolve the issue.
If you wish to resolve it yourself, you may use a soft cloth to clear the dust by manually pulling out the lens part..
If it doen't help, it may require opening the Camera
if you have condensation on the inside of the glass your camera has been shorted out maybe letting it dry out for a few days would work but you can also try a local camera shop and see if they can help.
Hi, Set jog dial on Auto (green mark) and press flash button (left button of navigation buttons) to set flash mode i-e auto, synchro, off etc. Below image shows flash button in navigation buttons.
