Question about GE Security Simon Xt Wireless Control Panel 40 Zones
I have a low battery on #6 but I don't know which one it is. How can I find out & how do I replace the battery?
2004 mazda 6 low beams don't work but high beams do
its probably the switch inside on the steering column check fuses first
Mar 20, 2013 | Cars & Trucks
Tip
7 ways to extend the life of cell phone battery
Batteries don’t last longer than a few days. But to be fair to the battery designers we have to admit that nowadays’ smartphones require much more energy than phones 10 years ago. We can’t really compare them but what we can do is use them with more care. Here are a few good tips how to go about it:
1. Turn off your Bluetooth – I find Bluetooth to be the most power hungry application; turn it off when you don’t use it
2. Disable sounds and vibrating alert – you don’t really need keypad tones to be on, do you? What about vibrating? It is surely useful on the meetings or in a cinema but most of time you’ll do just fine without it; I usually set up a vibrating profile to be used in places like cinema or theatre and in all other profiles I have vibrating turned off
3. Brightness – lower the brightness of your screen; not too low, otherwise you’ll destroy your vision
4. Setting the Power saver time-out and the Light time-out to the low values will help too (you’ll find them in the display settings)
5. If you are not using an application switch it off – you’ll get a list of all active applications by long pressing the menu button; this is a general rule that can be applied to any device
6. Games – it’s fun to play games on your way to school but they are power-hungry beasts; I can’t tell you not to play games but think about your battery when you are playing
7. Turn off your phone when you don’t use it – I know that for many of you this is not an option and I’m not sure if turning it off and on is even good for your battery but I heard this tip from so many people that I just had to mention it
on Aug 07, 2010 | Cell Phones
Replaced battery in crv and now headlights don't work
Check the low beam fuse in the fuse box, usually a 20A. If the fuse is blown/shorted during the replacement of the battery, your lights won't work. Replace the fuse if that's your case. Hope this helps.
More help: Moonlight Driving
Dec 29, 2012 | 2006 Honda CR-V
Loud noise from backup E5 350 battery
It sounds like your unit is not happy. When these things fail, they alarm and they must do so, or they don't get fixed, and then you're unprotected...
What fails usually is the battery, they just have a short life...So, they can be repaired, but most people replace, due to low cost to replace.
It is possible that the battery is okay, in which case, the issue is in the electrics. Again, fixable, but hard to have a tech open the unit and put in any part, and not be 3/4 the cost of a new unit.
If your unit is expensive, start testing, or send unit in. .....So, now what for your system? Again, replacement just works. You put the system down, replace the unit, power back on, and continue your life.
Oct 05, 2012 | APC Back-UPS ES 350 - UPS ( external ) -...
IT is overheating.I have already replased the thermostat,&waterpump.Both electric fans are working fine.Replased overflow pressure tank.still overheats within 30 min of run time.Did compression...
you probably have either the 3.2 or the 3.5 v-6. as 15 years as a chrysler tech, i would say you need a minimum of head gaskets replaced. compression is very low. but remember this, the heads have to be checked for flatness, and if they are warped over 6 thousandths they will have to be replaced. Don
Mar 06, 2011 | 1998 Chrysler Concorde
GE Security Simon Xt Wireless Control Panel 40 Zones Logo
65 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
