Question about Tablets & eReaders
I charged my tablet and turned it off for a few hours and now it wont cut on
Fully Charged my tablet and cut it off for a few hours and now the screen stays black and will not turn on
    New Friend:
    Problem Solver:
  • 15 Answers
Press and hold power button for a few seconds.. To run safe mode.
This is a common problem caused by power fluctuations.
Posted on Nov 13, 2015
Testimonial: "I have tried and the tablet will not cut on at all I even charged it again to make sure it was not completely dead"
5 Suggested Answers
msoufeer5
soufeer mon
  • 170 Answers
SOURCE: my tablet is fully charged
battery shell is weak please replace weak shel
pls vote me
Posted on Jan 22, 2011
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: my tablet froze and now
Hello!
Here you can try the following procedure to unfreeze your tablet:
First: Hard Reset
1. With the Samsung Galaxy Tab turned off, press and hold the VOLUME DOWN button, and then, briefly press the POWER button.
Second: Remove SIM card
1. Take out the SIM card and put it back in.
2. Then it will turn right on from the beginning if you press the power button.
3. If that doesn't work, it means it needs to charge.
Third: Resets
Try one from the procedures below
1. Hold the POWER button for 10 seconds
2. Hold the POWER and UP VOLUME for 10 seconds for recovery mode
3. Hold the POWER and DOWN VOLUME for download mode for 10 seconds
If none of them works. Remove the battery and leave it off for 10 minutes. Then, return back the battery. If problem persist in the future, I would recommend to replace the battery.
Posted on Aug 30, 2011
SOURCE: Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Posted on Jun 27, 2012
Mercedes Harris
SOURCE: charged sylvania tablet for 24 hours & unplugged it but no power
Many times the cause of this problem is u need a new piece where the charger plugs into the device because it shorts out.
Posted on Aug 20, 2012
Anonymous
  • 9 Answers
SOURCE: my galaxy tablet GT-P7510 wont turn on its fully charged
Hold down power up button until it starts. It can take up to 30 seconds before it restarts.
Posted on Oct 30, 2012
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
My Kurio wont turn on. It has a black screen even when fully charged.
hook it to computer and go to the kurio site and have them diagnose it or they will send you a box to send it to them to be fixed or replaced,tell them its less than 9 months old
May 04, 2015 | Kurio 7S Tablet
My nextbook is charged why wont it turn on
Are you sure it's fully charged (like for 12 hours)? If so, try holding down the power button for at least 10-15 seconds, maybe more. Sometimes that works.
Aug 11, 2014 | Nextbook Tablets & eReaders
Bateery is fully charged and it wont power up
My battery is fully charged but will not turn on?
Apr 30, 2014 | Visual Land Prestige 7 Tablet
New tablet just purchased fully charged it then pressed power button as instructed but nothing happens, black screen ???
have you tried pressing and holding the power button for a few second?
also try and charge it before turning it on.
Mar 12, 2014 | Leader Impression 7 Tablet
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
7" Zeepad 7.0 Allwinnwer is fully charged but wont work
I am problem with my tablet.. it wont go on home screen at all,, stay on andriod blue guy.. can i replace new one or something to make it work
Apr 19, 2013 | ZEEPAD MID Android Tablet 7 Inch WiFi
Dragon Touch tablet. It is charged. Why won't it turn on?
PRess and hold the volume up button and then power button together for a few seconds
Dec 24, 2012 | Android Tablets & eReaders
My literati wont turn on even if i push the reset button on the back. the battery was fully charged when i turned it off, and when i tried to turn it back on to read nothing happens.
Hm. Not sure how much help I'll be, but I'll give it a shot.
- Make sure the device is charged for at least 6 hours if this is its first use. If it isn't, charge it for several hours anyway and try it again. Make sure the charger is plugged all the way into the outlet and all the way into the device (mine sticks out about an eighth of an inch, yours might too). - Call customer service at 866-204-4714 and describe the issue. I had something a little like this issue (I was stuck at "Literati" screen) and they said to drain the battery and recharge it fully to see if it made any difference, and that if it didn't work they'll be sending along a package to ship it back to them for a replacement. If nothing works, ship it back to them for a replacement.
Feb 15, 2011 | Sharper Image Literati Reader 16375680042...
Tablets & eReaders Logo
80 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
