Once you listen to the voicemail on you alcatel phone you press the number "7" and it will delete it; Here is a link to step by step instructions Set Up and Access Voicemail on ALCATEL ONETOUCH Fling
SOURCE: alcatel c820a with prepaid t-mobile card
to connect to the internet you must activate the GPRS first from your
network provider ...The best thing you can do is to contact the
customer care of your network provider and ask for the activation of
GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you
will receive the gprs settings(profile) also ... make sure of the
charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if
the customer people tell you that your handset is not compatible for
the receiving of the profile settings then you must tell them to give
the manual settings(includes ip address,APN,etc) so that you can only
create the profile and input the information given by the customer care
people...
any further doubts reply me
i am always here to assist you ..
thank you
bye...
SOURCE: Unable to delete voice mails
hi all you need to do is press 7 to delete. if you want to save them press 9 to fast forward to the next one prress the number sign #
thats worked on all the cell phones ive had hoped it works for you.
SOURCE: How do I set up voice mail? I do not see i in the
press 9999 as your security code when you dial *86 for voicemail...
SOURCE: have no instruction manual, need
Call your voicemail and listen to the instructions. It should say something like "Press *number* to edit voicemail settings"
