Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
What is the warrenty on HE4t washers motors?
Warrenty on multi control unit
Kenmore He4t front load washer f 06 error code
This answer is actually from Sears Parts Direct: The F06 error code
indicates a drive motor tachometer error. This error is virtually impossible to accurately diagnose. The most suspect components that would cause this failure code are the drive motor, the motor control unit (control board) or the wire harness. In some instances, this could be caused by severely overloading the washer so that it cannot spin properly. Make sure that the washer is not overloaded. Another problem that could cause the error code to be displayed intermittently would be a loose wire harness connection that is affected by vibration when the washer is spinning at high speed. Good lucks, hope it helps
Dec 07, 2014 | Washing Machines
How to repair HE4t with HF code?
HE4T had problem on control board when early time version. Later they modified control board and find new version should fix your problem.
Apr 24, 2014 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have the F06 error code on my he4t washer. I've checked online with all of these "fix it" sites and had an electrician check the motor. All of the connections and the motor are fine. How...
The MCU is the motor control unit its in the lower panel down on the bottom
The CCU is the central control unit and it is up in the top behind the touchpad/cycle selector
Sep 23, 2011 | Kenmore Elite 45986 Front Load Washer
Error code F11
F11= Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. The board needs to be replaced. Here is a link to it.
http://www.repairclinic.com/PartDetail/Circuit-Board-or-Timer/1059575
Nov 25, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Have a HE4t. Giving us a f 11 fault on display. what does this mean
F11 is a serial communication error between the main contol board and the motor control board.
Here is a list of things to check:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Unfortunately if you do not have the proper equipment, you cannot narrow the problem down. More than likely it is a main control unit problem but that is only the most replaced part on your unit.
    Jul 16, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer stops with F11 code; door won't open
    F-11 ERROR CODE MEANS :
    Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    TO RESOLVE THE PROBLEM:
    • Check MCU
    • Check CCU
    • Check Motor
    May 05, 2009 | Washing Machines
    Iget a f-11 trouble code on my kenmore elite he4t washer.
    REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
    Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
    HE4t Washer
    "F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
    http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
    The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
    If you have questions, or require additional assistanc, please let me know. I hope this helps you.
    Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE4t washer won't spin
    The motor controller board is likely bad.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
    WILL HE4T RUN WITH KICK PANEL AND BACK PANEL OFF?
    The washer will run without the panels in place. As a technician it is common practice to troubleshoot with the bottom panel and/or back panel removed in order to see if certain components are working. The "F06" error is a motor speed problem. With this fault, the washer will shut down if the motor speed is not detected, or reach optimum rpms. The fault is usually caused by a failure of the Motor Control Unit (MCU) or Drive Motor. The following link explains how to troubleshoot:
    If you require addtional assistance, please let me know. I hope this helps you.
    Aug 17, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
    47 people viewed this question
    fordexpert
    Harvey Mahal
    Kristen Denison
    Kristen Denison
    Level 1 Expert
