SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
SOURCE: need an unlock code for a samsung tv model
You will have to contact Samsung Tech Support in order to retrieve this code. There is no other way to get it.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
SOURCE: what size of capacitor do
open the back and look. Mine has 4 10volt 1000uf capacitors that I plan on replacing tomorrow. I'm going back with 16volt 1000uf high temp capacitors so they don't go bad again.
