CHANGED BATTERY CAMERA WILL NOT TURN ON, LEFT FOR OVER HALF HOUR STILL NOTHING
SOURCE: wont turn on
Only use Ni-MH or AA-size alkaline batteries. Do not use Ni-Cd (nickel-cadmium) because the heat emitted can damage the camera.
I would suggest using e2 batteries from Energizer.
In the manual, on page 80 there is a description and procedure for discharging Ni-MH batteries (but NOT regular batteries, so don't do this with regular alkaline batteries) AND do not do this when the external power is connected.
Moving on... The discharging of the batteries procedure should happen when:
Follow these instructions:
The screen changes and discharging begins. When the battery level indicator blinks red and discharging ends, the camera turns off.
Remember to not have the camera external battery plugged in so the battery can discharge on it's own.
Then, at this point, recharge the battery using the external battery charger. This helps to "renew" the battery. This is because Ni-MH batteries will remember the last place where they recharged, and too many times, the memory "bookmark" gets marked to low and has to be reset, done by the recharge.
It may be necessary to repeat these steps multiple times. This effect is not because the batteries are deffective. This is a normal side-effect of Ni-MH. This is the reason the camera comes with a discharge feature.
I the batteries are old and don't function even after performing the discharge procedure as part of the normal operation of the camera (like of the year or two), then the batteries may have reached the end of their service life.
Hope this helps, if so, please rate FixYa! ThankYa!
SOURCE: card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
SOURCE: fUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
SOURCE: camera is fujifilm finepix s1000
pull batteries and re-install. if it repeats install new batteries.
