RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet Android 4.1, LCD Touchscreen, 800x480, 4 Hours Logo
A
Anonymous Posted on Nov 14, 2015
It says the launcher has stopped and it won't do anything. What can I do?
  • 1 more comment
  • shannon allen
    shannon allen Mar 01, 2016
    I'm having same problem. But can't do anything that I've read that helps...
  • shannon allen
    where is the reset button ob a z740
  • shannon allen
    My keyboard has went crazy.. I was trying to post a pic
Chris Baklik
Level 2:
New Friend:
  • Expert 169 Answers
  • Posted on Apr 05, 2016
Chris Baklik
Expert
Level 2:
New Friend:
Answers
169
Questions
0
Helped
29554
Points
473
Call RCA tech support or take it in to a store like ATT or telephone store and see if they will help you with the problem or try you tube on line about this RCA model
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
2answers
What can I do, Asus tablet says "launcher has stopped" and will not do anything?
Always try a reboot first. If that fails go into settings, go to apps, then might have to go to system apps, see if you can start it from there. If it starts and stops, could be another app is interfering or you got too much installed and are low in memory. You can try to install a startup manager app and make sure to turn off all unnecessary apps from auto starting. If that fails, you can then try to reset to factory defaults and start all over. Just reinstall your apps one at a time and make sure system is stable after each install.
1helpful
Can't use my tablet. Getting error: the process android.process.acore has stopped. Is there anything I can do?
Unfortunately, I purchased the same tablet and found it to be junk as well. I returned it and was sent an M9200...just as bad, so they refunded my money and I still have the terribly, slow tablet. Try resetting the tablet by uncovering the tiny hole to reset it covered by a small sticker on the back of the tablet.
My nook hd says "unfortunately, Home has stopped
You can use alternates to the Home app that defaults on Nooks.
The Home app and the alternatives are all what are called Launchers. You can make your Nook look and feel just like any other tablet you have ever seen. I\'ve personally been using one for years called ADW.Launcher on both my Nooks and just love it. The Nooks default default Home launcher is just a bloody pain to setup.
You can still use both launchers side by side. After running ADW.Launcher for a while you will just ask how you ever got around without it and never want to see Home again.
Jul 07, 2014 • Nook HD+
1helpful
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Display colors are screwed up
my son deleted everything I don't have a back-up the launcher has stop working I can't download or restore help me please
Received message: Unfortunatly launcher has stopped
You could try the free GO Launcher HD for Android at the Google Play store, (just Google "Asus tablet launcher"), but I find that if I restart the tablet when it says "launcher has stopped" or even just switch to another screen it carries on anyway, so it's hardly worthwhile installing another launcher for an occasional annoyance (so far anyway, fingers crossed).
2answers
My daughter's new Childpad is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to reconnect to wireless router but no joy. What can I do?
Look. It happened to me and drove me crazy. I was about to brick my new mobile phone. In my case it was the "Moon call log" icon on the home screen. Believe it or not when I remove the icon the error message no more appears when I restart the mobile phone. Then again when I place it (the icon on home screen) the annoying error message "Unfortunately, Launcher has stopped" will comeback again. In your case it could be any icon or widget.
I solved the problem by uninstalling the application and installing it back from Play Store unlike what I did before by installing it from the .apk file.
Regards,
Top RCA Tablets & eReaders Experts
 Mikey
Mikey
k24674
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
