HP LaserJet 3050 All-In-One Printer Logo
c
clearchannel Posted on Nov 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Squeaks (slight groan) when printing. Does it need lubrication and how do you do it?
m_hendy_eg
Level 2:
Habit-Forming:
  • Expert 91 Answers
  • Posted on Nov 15, 2015
m_hendy_eg
Expert
Level 2:
Habit-Forming:
Answers
91
Questions
5
Helped
34413
Points
244
No i think you need to replace toner cartridge with new good one
Testimonial: "It has been squeaking for the past years with occasional groans. New cartridge didn't stop the squeaking."
Can the rollers be lubricated to stop squeaks and groans? If so, how?
You do not lubricate rollers directly. You lubricate the gears driving the rollers. I generally use white lithium grease.
Why do I get 3 groans during calibration accompanied by a 51.2m error ?
51.2 is a laser error.
there should be another number after the 2,
0 = black laser
1 = cyan laser
2 = magenta laser
3 = yellow laser.
The groan is most likely the polygon motor has lost its lubrication and may just need to be cleaned and re-lubricated.
You can also try reseating the connectors from the lasers to the DC controller PCB...
Squeaking suspention
The Explorer has an unusual front suspension called a Torsion Bar system (no springs). As they get older, they squeak and groan.
All the parts are put together with bushings between the metal parts, and as these get older, the get dry and inflexible. And this causes the groans and squeaks.
At worst, they can make your handling sloppy. A new set of control arms, tie rod ends and ball joints is about $200 in parts, plus 3 hours of shop time to replace them. When you replace these parts you also get new bushings which usually stops the noises.
Toyota sienna 2000 suspension squeaks and groans
check your lower control arms, the rear bushings go bad and ride againts body causing all kind of nosises. good luck
GROANING & SLUGGISH SEWING MACHINE
it would be a good idea to have a sewing machine technican
check the machine to see why it sluggish
My hp 2840 all in one laser jet printer squeaks when it is printing. How do I lubricate my 2840 HP laser jet printer?
Corosol technology is older,slower sounds also too high, it is not suggestible to lubricate the moving parts because of cartrides will move while printing result lot of toner particles raises in printer chamber,if this particles deposited on lubricated area will abstract the moving spares. If you can do the periodical maintenance, use silicon grease for moving parts..
1helpful
I AM USING A BROTHER MFC 7340 SINCE 1 YEAR: NO PROBLEM EXCEPT WHEN PRINTING FROM PAPER TRAY, THE PRINTER SQUEAKS AND MAKES NOISE THAT IF ANYTHING ELSE WAS DOING THE SAME NOISE YOU WOULD THINK IT NEEDED...
The problem actually is probably due to needing lucubration. I would apply graphite lube to any rollers or gears in the user serviceable area. print 100 blank pages to make sure that the lube is spread thoroughly through the printer.
Good Luck!
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Oven Door Hinge Squeaks
its not the hinge,,its the sping in the hinge,,you have to replace it,,,be careful with ludes on stove...onthejob
4helpful
Squeaking
the squeak is coming from the drum unit. If you take out the drum and rotate it by hand it will most likely give you the same noise. you may be able to stop it by pouring some toner on it, but in reality it is more annoying than a problem.
there is a blade that scrapes off excess toner from the drum, it is slightly dry and causes the squeaking, technicians usually use a special powder that looks like baby powder to "lubricate" the blade, and stop the noise.
k24674
Grand Canyon Tech
Grand Canyon Tech
