Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
you need an optical cable which it's sort of mentioned in the manual, but because of the multitude of possible ways to connect the TV to the sound surround, I did not figure out either.
I got my optical cable at BestBuy for about $45.00
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
